The M12 shares the same tone stack as the Dr Z Route 66. This allows for standard treble and bass sweep up to 12:00. Beyond 12:00 the gain increases in the respective frequencies. The loudest and cleanest tones are found between 10:00 and 2:00 on the bass, treble, and volume controls. Also up front is a Hi and Lo sensitivity switch. Much like the Hi/Lo dual input on many of our amps, this switch will yield clean sounds from hotter pickups in the Lo setting. You can also use the Lo setting for a cleaner input signal for heavy drive and modulation pedals. The Hi setting will yield the strongest dynamics and input gain.
http://i726.photobucket.com/albums/ww261/Treewig/S0746077.jpg
http://i726.photobucket.com/albums/ww261/Treewig/S0736076.jpg
http://i726.photobucket.com/albums/ww261/Treewig/S0726075.jpg
