Hi folks, I bought this mod that has 2 caps,a DPDT switch and some wire,basically you remove the 0.01 cap on the board
then solder the wire to the 2 tags on board then to the 2 centre tags on switch.
The other tags have a 0.01 and a 0.02 cap soldered to them thus enabling you to toggle between the 2 values.
Great....the only problem is the instructions are for a more modern version [ mines a Rev C version] therefore I'm a bit stuck
regarding which 0.01 cap should be removed from said board. The instructions say its situated above Q2 but that don't mean shit
to me because of the different circuit layout.
Does anyone know which is the cap to go walkies.....the pic is my board,cheers.
p.s. I think the position may be C5..........
ie; which cap to remove and add the wires to the board....
And heres where the switch hides...........
Good luck..........
