Sorry about the pic quality.
Heres the spec (lifted from Andertons of course)
General Spec
50W/15W, all valve, two channel guitar amplifier with reverb.
Valves
Power Amp: 2 x EL34/6L6.
Preamp: 4 x 12AX7/ECC83. 1 x 12AT7.
A bias switch is situated on the top panel of the amplifier so that the bias voltage can be set to a range more appropriate for EL34 or 6L6 use. It should be noted that bias adjustment is still required when changing output valves.
This Rob Chapman signature model ships with Rob’s preference of EL34s.
Transformers
Custom wound and designed in-house.
Construction Methods
All power supply and switching circuitry is PCB mounted. All circuitry directly relating to valves is hand-wired on 3mm turret board and point to point on the valve bases themselves.
Controls
Clean Channel Gain (with Pull Crunch feature), Channel Select Toggle Switch, Overdrive Channel Gain, Gain Boost Toggle Switch, Gain Boost, Bass, Middle, Treble, Clean Master, Overdrive Master, Reverb.
Features
Rear Panel
Rear panel and rear grill fabricated from 1.2mm Stainless Steel.
Fused mains inlet; High Tension Fuse; Speaker Outputs: 2 x 4 ohms, 2 x 8 ohms, 1 x 16 ohms; Effects Loop Sockets, FX Mix control, 2-Way Footswitch Socket for Channel and Gain Boost and 1-Way Footswitch Socket for Crunch On/Off.
• Youtube - https://www.youtube.com/@Goldeneraguitars
Gibson Les Paul Standard
custom shop fender tele
custom shop fender strat
mesa boogie Lonestar
http://www.robchapman.tv/forum/threads/victory-silverback-amp-raffle-10-to-cancer-research-uk.35063/
