It's just occurred to me that 'classic' and oftentimes simple circuits, with lower parts count, are normally only available as a more expensive range of production or from boutique builders, yet newer, more modern circuits with multiple channels, several pcb's and in built boosts are in the budget ranges.
Is it just because people are happy to pay more for a simple circuit? I can imagine that Marshall doing a jtm45 circuit in a lunchbox sized chassis and made here in the UK would be relatively affordable and a huge seller because... Well, Jtm 45s are great sounding amps.
I know, typically, cheaper circuits are made off shore but the parts count is much bigger, so it makes me wonder why they don't make a simple circuit amp in a smaller head here in the UK.
Surely tooling for a PCB would pay for itself with a timeless circuit, and would possibly make more money than the expensive reissue ones that are hand wired. They could even simplify the circuit somewhat and give a global volume and tone control, much like the 18w Wem.
Edit: in a similar case, orange make the 15 watt Jim root terror using something resembling the rockerverb preamp and it sounds immense. I'm guessing that preamp is relatively complex, and they've kept cost down with power and off shore manufacturing.
That said, I do a fair bit of development work for a well-known pedal manufacturer, and components for "classic" circuits have really started to climb in the last few years as mainstream demand drops, though for the time being it remains a drop in the ocean compared to labour costs.
I don't get the whole "lunchbox head" trend anyway. You still need a cab, so it's not like they save any space on stage. 5w maybe, but 30w and up, what for?
As was mentioned, transformers are the limiting factor with a JTM45. By the time you've got the trannies, choke, 2 big old KT66s with appropriate spacing, external can caps, you might be able to drop a couple of inches off the 17" chassis, add the savings on the cabinet and you could get it down to maybe 18" including the head box. Not really lunch box size.
It's not wasted, it's a REAL lunchbox amp, keep your sarnies in there and hey presto, a lovely toasty snack at the end of every gig!
(Hint; don't use tinfoil )
I suppose the main point was that a lot of smaller amps are pretty complex and are often regarded as sounding not as good as tweed deluxe, dominator etc. The tiny terror, for example, doesn't sound brilliant to my ears, though some love it. The mofo has 2 channels, a 2 watt mode and an effects loop I think.
But even smaller heads are - my old laney lh50 fit perfectly on top of a smaller 1x12, and was nicely portable despite a feck off toroidal at one end. Much easier than a larger head that weighs half as much, so to speak.
But that's the pcb one Also, valves vary. Maybe this one just had bad valves!
