In the words of the late Lou Reed, it's a lonely Saturday night. So...output transformers! Can I use a reverb transformer as an OT for a low-powered push-pull power amp? I have a reverb transformer hanging about, and want to build something around one watt. I know the Firefly on AX84.com uses a self-splitting 12AU7 in push-pull, but will it work with the reverb driver (which I think is single ended)? I really dislike single ended amps (so glad I bought that Champ 12 a couple of weeks ago) so the push-pull side of things is non-negotiable.
RS do a little output transformer that works well in the Firefly and similar low power P-P circuits (part 210-6475) which used to be quite cheap, but I see is now approaching the price of small Hammond transformers (but it sounds better than the 125A ).
