I built a Toronado based partscaster fitted with Mojo Wide Range Humbuckers and I had it out the house for the first time at rehearsal last week. I was getting a nasty buzz when not touching strings - when playing at home I thought this was because I was right beside my laptop, so I was disappointed that I was also getting noise in the studio.
I will check all the ground connections, but are WRH pickups especially noisy? Should I be thinking about shielding the control cavity?
I had always understood that if it buzzed a lot when not touching the strings and the buzz went away when you DID touch the strings, it could be a sign that the strings/bridge weren't earthed.
Is that an old wives' tale?
What's happening is that when you touch the bridge or strings you are grounded through the guitar lead and amp. Your body then acts as a shield, which prevents quite a lot of noise from reaching the pickups.
If the noise goes away when you touch the strings then it's a shielding issue.
Once I shielded it using copper foil it became (and still is) dead quiet.
