Step-down transformers.
LoobsLoobs Frets: 3854
Anyone using one? Are they heavy to cart about? Do they affect the amp negatively or is it safe?
I'm considering picking up a head in NY in a few weeks.
  • woodywoody Frets: 74
    I've used them for years.never had a problem. Get yourself a medium sized builders transformer.plug it in to make sure it's a nice quiet one.some of them hum a little.wire a 3 phase plug to your amp,or a plug board and bobs your uncle.
  • LoobsLoobs Frets: 3854
    Can you link one?
    www.screwfix.com should bring up something for you.a 500 va is what I use as the 1000 is a bit heavy.
  • surfguy13surfguy13 Frets: 133
    I've been using stepdowns for 30-40 years in different amps and they work faultlessly and in my experience have never resulted in any hum or excess noise.  I use mine in combos, not for heads, so they sit happily inside the cab but with a head you have to think about where its going to sit.  if you use the head with an open backed cab then no problem but with a closed back cab there's no obvious place to place it so that it's out oif harms way.  Of course you can just sit it on the floor and will work fine.  I use this one for my 50s Fender Twin:
    http://www.maplin.co.uk/p/maplin-110v-to-230v-300w-voltage-converter-up91y
    And this one for a 50s Princeton:
    http://www.maplin.co.uk/p/tacima-110v-to-230v-500w-voltage-converter-n59hf
    The Tacima is very high quality and as a result very expensive but the Maplin transformer has been used in my Twin for years and it works perfectly.  Yes, they add a little weight but what the hell?!
    They look great, thanks!
    Hi @surfguy13 , nice to see you on here, hope you are well my friend  :)
    Are you sure the links are correct ?
    ~ maplin-110v-to-230v-300w-voltage-converter
    Looks like they are step up transformers to me ~ Allows you to operate UK equipment in the USA
      Yes Chris, you're dead right!!!!  :)  I got it the wrong way round....the links should be:
    http://www.maplin.co.uk/p/240v-to-110v-300w-voltage-converter-vr05f
    http://www.maplin.co.uk/p/300w-uk-to-usa-voltage-convertor-n53hf
    Humble apologies, a bit of brain fade....
  • That's the one i use never had a problem with it. made in the uk as welll. no brainer.
