Hi there, I wondered if I could have a little science lesson and advice on what are the various safe ways to operate my marshall 8008 poweramp.
First of all, here is my cab:
It has 2x 16ohm WGS speakers in it but I kept the wiring the same.
In a separate thread, ICBM very kindly contributed this:
In mono into 8 ohms, one side will deliver about 45-55W I think. (I did check once, can't remember the exact figure but that's close enough.)
In stereo into 16 ohms per side, it should deliver around 25-30W per side, or 50-60W total… basically the same, but you can use stereo processing if you want and it's slightly more reliable since the amp is running even more conservatively.
How does stereo work? Would it be possible/safe to use the channels of the 8008 for different purposes, for example have an 11r in channel a, output to the left side of the cab set to stereo, and a zoom g3 in channel b in the right side? Do the channels directly relate to the speaker, so in stereo the 11r would only come out of the left speaker and g3 only out of the right? (I'm thinking when a mate comes to jam to save him lugging an amp.
If the above is possible, is it possible to just have one output of the 8008 plugged in to the cab but it still set to stereo? (I have no reason why, just curious) does the cab need a load into both jacks if set to stereo?
Also, why is it slightly more reliable to run the 8008 in stereo rather than mono as it is running more conservatively? Surely the best way to run it would be at full 80w into 4ohm?
Another one, I read that into a 16ohm speaker the 8008 would give me between 25 and 30w, therefore into 2 16 ohms in stereo it would be 50-60w? How come? If the channels and outputs are independent then surely it would be no different to using 2 separate 30w SS amps... Surely using 2 amps wouldnt double your power?
Finally, the 8008 manual says that input B can accept a signal from mono equipment via linked mono mode that could be output via both speaker outs. That will give me the same power to the speakers as having stereo inputs right?
Thanks
Football is rubbish.
Lol @octatonic
Out of curiosity, on a valve amp that has 1x8ohm out or 2x16ohm outs, with I cab like mine that can run stereo 16ohm, what would be the better way to run it? With one cable in mono or 2 in stereo?
My ht50 has 2 sockets labeled "1x8ohm or 2x16ohm"
Feedback
Feedback
