Hi all
Currently when I do recording I use my W10 laptop, with guitars recorded through my Zoom G3 via USB into Audacity (because Cubase doesn’t seem to like it, probably user error), then vocals either using a USB condenser, or more recently using my TC Voicelive, again via usb into Audacity. My computer seems to struggle with allowing me to use my interfaces within Cubase so I tend to create guide tracks there, export them to mp3 then use Audacity to record freely along to the guide tracks then export the good takes to wav to import into Cubase.
But it’s a bit of a faff, and I always feel like I’ve got wires everywhere with it not being a permanent setup, with the guitar to fx, usb lead to comp, headphones etc, I feel like if I move the wrong way I’m going to pull something out. I’d also like to be able to record more instruments, for example keyboards, which at present is yet more faff.
So I’ve been thinking about digital multi track recorders. Are there any general pros and cons that I may not have thought of with this? Seem to be a few decent offerings from Boss, Tascam and Zoom et al.
I was thinking I could effectively record basic drum machine rhythms to repeat to be the equivalent of the guide tracks I create for Audacity (or even more detailed drum tracks exported from Cubase to the Multi Track). Then record onto the multitracker again the same way as Audacity, but without having to work a computer at the same time. I’d effectively create the draft recordings on there, then export the files onto my computer where I could sequence them in Cubase and apply all the effects and polish required. I am hoping they export the individual track/audio files rather than an overall mix of everything???
For context, I’m generally fond of doing things the most minimal way possible – I rarely use more than 8 tracks in Cubase on finished projects, let alone just the recording phase. I’m also not an amazing musician and this is purely for my self-indulgent leisure (and Fretboard challenge entries!) so not worth breaking the bank. I’m only really going to need to record guitars, vocals, and keyboard as I don’t use bass or drums, if I use them I use VST instruments.
Am I better looking into these methods, or something like the rack mounted multi-input interface on sale in the classifieds and persevering with the laptop approach?
Thank you
I'm scared and I'm waiting for life
I see your local to me ( Walsall), Id be happy to talk you through my setup at home although its a bit more complex than what you are after I think .
https://twitter.com/spark240
Reddit r/newmusicreview
Interesting insight there thanks. The thing is I don’t have much room in my music room (it’s not really a music room, it’s a spare room that I’m allowed to use!) so having somewhere to put the laptop within reach whilst operating the other stuff is not the simplest of tasks, coupled with the fact that I seem to have to set up my Cubase every time I try to record something (it never likes my usb inputs and also the VSTs seem to occasionally move for no apparent reason). I just thought something like a small pedalboard with the relevant gadgets velcroed on it, ready cabled up, might be an easy way to just plug in and record.
Something I also vaguely heard of (albeit more expensive) is a digital mixer that records to usb? But I guess that records the whole mix not the individual inputs separately
http://www.presonus.com/products/Capture this will allow simple multi-track recording, you can then import the wav files into a DAW of your choice? you will still need an interface for this though
You could even go as small as a hand-held recorder - there are models now that will do four track recording - although a modern 8-track machine will probably be quite compact.
In the past, I've recorded in this way - once with a Boss BR8 (?) 8-track machine and a few times with a Yamaha AW4416 16-track machine. Both these machines come from the days before usb connection to computers for transferring audio but it was still possible, if a bit more time consuming. It allows stuff to be recorded anywhere and then brought back to the computer for mixing, etc.
Use a patch bay for inputs and outputs.
Digital Multitrack recorders are a massive compromise- I'd never go back to one.
Football is rubbish.
Winny_Pooh said: Sorry I disagree, couldn't even get the simplest of functions to be working on that when I've tried it and I don't really have the free time to scale the really steep learning curve
If you don't like having to fire up cubase everytime you want to record something then perhaps a multitrack recorder (Zoom R8/16 or the Tascam ones or whatever) might be the way to go, but I wouldn't underestimate how simple a USB interface into the laptop can be. There's a video by JustNick on youtube called something like "how to record guitars" which, I think, demonstrates just how simple it can be.
My last Fretboard Challenge entry took 3 hours start to finish. It would have been half that if the IT had worked
I capture raw tracks with a Tascam DR-100 but it is a bit limiting, so I've just ordered a 24 track portastudio. 8 XLR inputs, 19 faders, monitor outs, external fx sends for 300 quid seems ridiculous value to me, but lets hope it is usable! I'll post back when I start using it later this week/next.
