I've got a small spare bedroom that is currently used as storage and I'm thinking of getting rid of most of the crap that's in there an turning it into a "tracking room". The wife may think of it as a "dressing room" but that's another story lol
It would be great to record guitar cabs in there, usually powered by small wattage heads but as we're in a flat there are neighbouring properties upstairs and on one of the walls. Clearly this rules out just chucking a cab straight in there and going for it even with a 5w head.
I notice on some of Pete Thorn's youtube videos that he uses a system called ClearSonic with reasonable results, here from about 11 mins in, and a ClearSonic demo video after that:
Does anyone have experience with ClearSonic stuff? Anyone used a UK alternative or equivalent? Does anyone have experience of a similar project like this, like creating a tracking or isolation room at home? The room is about 7 feet by 8 feet...
Budget would be about a grand absolute top end and I'd rather not do anything too destructive to the room. It would also be nice to salvage some value from the project if I moved although that's not on the cards at the moment....
I'm still expecting to have to use some attenuation with the amps and I'm not expecting to be able to use this space at like 3am - I'm thinking of getting a space where I could sing or have loud home practice levels of guitar (whatever that means?) without totally pissing off the neighbours. I'm not thinking of putting a 100w stack and drum kit in there :-)
Any thoughts or references to resources would be very much appreciated as I have zero experience in this subject. Cheers!!
EDIT: initial thinking is to use some kind of amp isolation box like the ClearSonic in combination with some level of soundproofing in the room to further reduce pollution to neighbours. Aim is more for recording than practice...
I have a better solution
I had a double skinned large oak box made, with 3 speakers and 3 mics within it
Outside it, you could only hear the transformers rattle and the guitar strings, even with a 100w amp maxed out
Now I never use it, if you are interested, PM me, because I would sell it.
see: http://ceriatoneforum.com/index.php?topic=1969.0
I made a pespex screen using the Clearsonic hinge, but for a different reason, to tame the beam in front of my cab and for that it works well, better than the Jay Mitchell Donuts, but I suspect thats not what you want it for. Even a cranked 1 watt amp is going to be too loud in a flat!
I've been meaning to do something similar myself and I've found as a general rule density and air space are good sound proofing, so a box within a box leaving an air pocket between but I think the bigger the box would help with sound pressure levels and the problems they can cause on the mike.
One cock up I did do as a kid when doing the 'pile carpets over the cab' set up was forget that the amps output was greater than the cabs speakers and because it was quiet I kept on cranking the volume each time until... silence and two blown speakers, doh.
Basically.. You're not going to achieve what you want with the perspex panels alone - these actually act as reflectors and make the problem worse - put a screen round the front, it reflects on to the back wall; screen all round, the sound goes up. They also make the mic'd sound worse because of the second reflection into it..
However, the solution here is absorption, which you see in the PT video and later in the Clearsonics one. The sorber panels are like a carpet covered panel that has material inside, and they actually absorb pretty well. If you could surround and lid the amp with sorber, i'd expect to be dropping probably 10db, maybe more, off the cab volume.
It wouldn't be true to say that they don't change the sound - the soft surfaces definitely cut the top end, but not drastically. Also, creating a box will, unsurprisingly, make the recorded sound a touch boxy - purely by reducing the 'room' size. How much this affects you vastly depends on your mic choice and technique.. A hypercardioid close mic won't be much different, a cardioid condenser at 18" will be much more so!
