Acetone staining on nitro
Hey folks,
I've seen a Gibson LP where someone has used acetone to remove marker pen from the nitro. It has done the job by left a tide mark.
To properly sort it I presume a full refinish would be required. Aside from that is there anything that could be done to improve it ( other than putting a sticker over it!).
  • FatfingersFatfingers Frets: 501
    edited September 2016
    Could you not cut it back and repolish it?
  • ElwoodElwood Frets: 461
    I've no idea, can that be done?
  • paulnb57paulnb57 Frets: 3222
    Costs very little to try.......
  • impmannimpmann Frets: 12766
    You try some gentle use of T-cut to blend it back in.
    What does?
    I don't own the guitar . . . so I can't try anything :). I'm just looking into what could be done to rectify a previous owner being a loon.
    Any experience opinions?
  • octatonicoctatonic Frets: 34318
    Some 0000 wire wool might sort it out.
    I had a guitar with some nitro burn that softened the finish and managed to fix it with wire wool.
  • CorvusCorvus Frets: 3095
    It depends how bad it is and whether it's just the lacquer affected or if it's a solid colour, etc etc. T-cut might work, or similar cutting compound. Might need local sanding before polish. Might need a localised refin/repair.
    Is a localised refund actually possible with nitro?
    It's black so would be easier than a burst.
    Nitro melts into nitro, but black is not easy, it shows every tiny thing clearly.
  • DeadmanDeadman Frets: 4159
    edited October 2016
    I've done it twice this week on the back of a Les Paul (two scratches down to wood) and you can't tell at all now. As long as you follow a few relatively simple steps it's not that hard to do. However! If you're in any doubt whatsoever don't just dive in as you could make things worse.
    If it's just a simple case of removing ink I'd try t-cutting it first. If it's gone any deeper I'd then try some light abrasion, using micromesh, 3200 grade. Then T-Cut again. If that didn't work I'd be doing the above.
