You mention the depth control seems to be the wrong value what did you use?
I'll check it again tomorrow.
Do do you have one of these pedals?
Do you have the right taper pot for the depth control? If you have a log/audio taper pot in there it may well act as you describe.
Otherwise, it's probably worth checking for correct values, shorts, dry joints, that sort of thing, though you probably know that already!
I said maybe.....
