What size iron is it?
Football is rubbish.
to answer the above
yes i tinned the tip
yes i had a damp sponge. once i rub it on the sponge you can see the tip get shiny again. when i went to apply the solder, not much was happening. i mean, to solder to wires together, should take seconds. the solder just runs off onto the solder mat.
iron is about 30cm and 45w
Something is definitely amiss, for sure.
I said maybe.....
not sure. no variable temperature . the tip does not change colour
thanks
I said maybe.....
