FS: ProCo Rat with the wrong pots. £20 posted SOLD.
HeartfeltdawnHeartfeltdawn Frets: 23195
edited October 2016 in FX £
I shit you not. Chinese RAT, belonged to some guitarist out of Busted, and it was wired in the factory with reverse log pots. The Rat thread on this forum from last year threw up this info:
http://www.thefretboard.co.uk/discussion/comment/1084320/#Comment_1084320
This means there's a limited range eg. the EQ goes from 0 to max within the first 20% of the pot's travel. Same for volume and distortion. The distortion is 0 to max within the first two lines on the dial mark going clockwise. Well used as you can see. No screws in the base plate. Battery door missing. The battery clip does work though which obviously makes this oh so much better.
Actually sounds pretty good. Footswitch is fine.
£20 posted with PPG. Pictures up in a bit.
http://i.imgur.com/mRwrQyO.jpg
http://i.imgur.com/xoFmgic.jpg
http://i.imgur.com/Jf2hkpo.jpg
