Given that there's no easy way to set the overall pickup height of a dogear P90, people sometimes raise the polepiece screws to get a little extra output. It's common on the bridge pup of a 330 or Casino due to the natural dominance of the neck unit.
If that doesn't sort it, people often shim them. My Casino has a home-made one out of an old mouse mat! The ES330 is probably worth the real thing.
Maybe I should wind them down and then adjust myself to taste. Each polepiece on the bridge and neck are raised differently which is interesting.
Ive just strung it with 11s so I'd imagine that'll change the balance of things.
He then had to superglue it back together and make a mousemat shim for the pickup. That last bit probably narrows down the potential suspects....
The tuning is a bit sketchy so I'm going to see about getting the nut replaced as my band mate's 330 had the same problem due to a poorly cut nut.
