You'd be better off gluing the guitar to the wall with Araldite.
Use the same concept of hanging the guitar via the strap buttons, but rather than threading the buttons into a hole, have it so the guitar can be slotted downward into the brackets, so you can easily just lift it out.
You might need stronger metal bracket, but still seems like it would be better than some hefty wall mount stand.
If they were sturdy enough in the wall, then they'd be as safe and easy to use as any stand.
