SOLD: Zoom G5 Multi Effects and amp simulator - in mint/as new condition
The Zoom G5 is an excellent bit of kit, with some brilliant effects and features, many of which are conspicuous by their absence in the rather dull looking G5n. I bought it for home use so its immaculate, virtually new and in mint condition (as far as I can see there's not not a mark on it). Boxed with original PSU and manual, with everything still in its original packaging. I have three Vox Tonelabs and a conventional pedal-board already, and combined with a critical lack of space (I even have to keep one of my guitars in the living room), its just not getting used.
Selling for only £135.
I'd ideally prefer pick-up or to meet-up in North London/Barnet/Potters Bar/Enfield. If I have to post out I'll need to check postage costs but I'll only add on the actual cost and will let buyer know and agree this before finalising everything.
- 123 effects, including distortion, compression, modulation, delay, and reverb
- 22 amp/cabinet models
- Tube Booster (with real 12AX7 tube!) for added warmth and up to 16dB of overdrive
- 4 backlit LCDs with contrast control
- Intuitive user interface
- Ultra-fast (1.6 ms) patch change speed
- Up to 9 effects can be used simultaneously, chained together in any order
- 297 memory locations for storage of factory and/or user-created patches
- Input jack accepts standard mono guitar cable
- Active/Passive switch
- Dual mono output jacks for connection to amps
- Dedicated stereo headphone output
- Balanced XLR output jack with ground lift for DI connection (pre- or post-effect) to line-level devices, mixing boards, and recorders
- Store and Swap functions make patch organization a breeze
- Auto Save function for automatic saving of all patch parameters
- Onboard chromatic tuner supports all standard guitar tunings, including open and drop tunings
- Tuner range of 435- 445 Hz
- Looper allows recording of up to 60 seconds of CD-quality phrase recording
- 41 built-in rhythm patterns which can be used in conjunction with the Looper
- Z-Pedal for full three-dimensional control over volume or selected effect parameters
- Control input for external footswitch or footpedal
- Included AC adapter
- 2-in/2-out USB audio interface for PC/Mac computers
- Compatible with Zoom Edit&Share patch editor
