FS: Gigrig QM6, PedalTrain Jr, Moen GEC8 Jr, Mooer Pure Octave, Recording Load Box
ssuttiessuttie Frets: 9
edited January 2017 in FX £
Moving on some currently unused items.
 PayPal Gift preferred and includes delivery: -
  • Gigrig Quarter Master 6 - £95        Boxed / instructions
True bypass loop switcher. Original version (not QMX). This was ordered as a custom order as one loop serves as a latching switch (which I used to switch in the mid boost bump on my amp) but can be used for a myriad of things; amp channel switching, favourite switch for a small box Strymon etc..
Currently attached to a PedalTrain Jr also for sale as below.
  • PedalTrain Jr - £30                       Soft case
Includes soft case. Well used / gigged but perfectly functional. Has a cut-out underneath where I mounted a Cioks DC-10 but not visible from the top.
The above two items are still attached (as photo) with the Gigrig PT brackets and will sell together for £115. Also happy to separate.
  • Moen GEC8 Jr - £105                Boxed / Instructions
Brilliant programmable switcher - so simple to use, everything controlled & programmed by foot - no bending over required.
8 loops, tuner out and 2 programmable latching switches. 24 presets, 4 presets * 6 banks
  • Mooer Pure Octave - £30             Boxed / instructions
Hardly used. -2, -1, dry, +1 and +2 octaves and all combinations of.
  • The Recording Loadbox - £75        Boxed / Intructions
Great device for using any valve amp direct to desk or recording straight into your DAW. No speaker cab required.
I used this for recording my 65 amps head direct into Logic using the Two notes Wall of Sound plug-in with really good results.
From the website: -
http://www.dennismarshall.co.uk/load_box.htm
"Record your amp at huge volume with no sound coming out of the speaker!
Works with any guitar amp.
This is an upgrade of a design I did several years ago. At that time it received a 5 star review from Guitarist Magazine in 2008.
The concept is to be able to play your guitar amp loudly without disturbing the sleeping people at the end of your street - or even closer.
Plug this load box in line with your speaker lead coming out of the rear of your amp and switch between normal speaker operation and no sound from the speaker. The recording load box maintains a load across the output of your amp whilst the speaker is switched off. You don't even need a speaker plugged in.
You can either output to headphones direct via the centre jack output of the combi socket or using a standard XLR microphone cable, output balanced line direct to recording desk. Both outputs are speaker simulated and variable in volume. The volume control does not attenuate the speaker.
Customer comments on the Load Box
"I have to say I was VERY impressed with how the DI sounded through full range speakers. Having owned both a THD Hotplate and a Rivera Rockcrusher, I have to say that this sounds just as good (and perhaps even better!) than the Rockcrusher, and most certainly better than the Hotplate."
TT Netherlands Nov 2014
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/image_zpsd7bc4gih.jpeg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/image_zpsnb8fnyus.jpeg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/image_zpstj9rinqq.jpeg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/image_zpsfonebxaw.jpeg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/image_zpsbv8udlur.jpeg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2523_zpsyek6iuji.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2521_zpsx2nzkdcu.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2522_zpsnk4pon90.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/image_zpsea6wzvgv.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2525_zpspikdomsp.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2526_zpsq7ym1xrg.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2529_zpsl4lf5mhn.jpg
http://i1010.photobucket.com/albums/af228/ssuttie1/Mobile Uploads/IMG_2527_zps2i17bede.jpg
  • PlutoPluto Frets: 1
    Hey there! Does the pedaltrain come with the velcro?
    I have a roll of Velcro from my PT2 I never used - I'll throw that in free.
  • MrTMrT Frets: 21
    @ssuttie - did the PedalTrain Jr sell? If not, I'm interested - I've tried PMing you but not heard back. Can you PM me if it's still available. Thanks!
    PM'd
    ssuttie said:
    PM'd
    I'll take it if Mr T doesn't. Also PM'd a while ago and never heard back
