Hi all,I wonder if you could give me some feedback on this particular setup
So guitar goes into the input of the G-system
4 loops with various OD/Dist pedals
The 5th G-system loop goes into the input of the Egnator Pre-amp
From the Egnator Send I go into a little box which splits the signal, one going into the G-system Return the other going into a small Fender Pro Jnr (Dry). Do to the hot signal coming out of the Egnator pre I need to attenuate this down (500K pot?) or do I go into the middle lug of the pot, with one side going to the G-System the other to the Fender (more like a blend knob). Also should I put a buffer before the splitter box or will the pre-amp have buffered the signal enough?
One of the outputs goes to the Egnator Return the other to potentially another amp (future proofing for Wet/Dry/Wet).
I'm taking the G-system and pedals out the rack and putting it all on the floor (there will be other things before the G-system such as fuzz/octavia/Uni-vibe and Wha.
Any observations? Am I likely to get loads of hum?
There are a couple of pains with the G-system and Egnator
a) The loops are buffered so useless for the fuzz and octavia
b) The volume on the Egnator is pre-FX loop so the output is too hot for the Fender Jnr Pro. which does not have it's own FX loop.
Another Idea I have is to have the Egnator as a dry and the G-system outs feeding a mesa 50/50 power amp in stereo.
Boost in the FX loop. Before or after time/modulation FX.
But I like the combination I've had them in Stereo before both wet but want a dry and a wet signal
