Sold: Monsterpiece NPN BC108 Fuzz
The start of a spring clearout. All prices assume PPG and include delivery to mainland UK.
First up, a custom built NPN BC108 Fuzz Face by USA boutique builder, Monsterpiece. The finish is a silver sparkle (tricky to capture in the pics) and has a violet LED. Top mounted jacks. The toggle on the side is a battery on/off switch so you can leave it connected on your pedalboard without draining the battery - just flick the switch. Also has a 9v DC input if you want to run it from a power supply.
In addition to the standard volume and fuzz controls, this also has a bias pot (the one in the middle) so you can easily alter the character of the fuzz. Super tidy wiring.
If you've never heard of Monsterpiece, just do a search on "The Gear Page" forum site, they are extremely well regarded by fuzz afficianados.. £80 Delivered.SOLD
<a href="
http://imgur.com/P1o7WLG"><img src="
http://i.imgur.com/P1o7WLG.jpg" title="source: imgur.com" /></a>
<a href="
http://imgur.com/8dPY8I4"><img src="
http://i.imgur.com/8dPY8I4.jpg" title="source: imgur.com" /></a>
<a href="
http://imgur.com/ksBHYu8"><img src="
http://i.imgur.com/ksBHYu8.jpg?2" title="source: imgur.com" /></a>
J Rockett WTF Fuzz, designed by fuzz guru Paul Trombetta, complete with original box.
Sensational fuzz capable of everything from overdrive up to gated fuzz and the famed Trombetta trombone/ horn type sounds. Also has a separate built in boost to help you punch through the mix when it's time to let rip with that epic solo!
Superb clean-up from rolling down your guitar volume making it a really dynamic and musical fuzz with loads of control. Superb, heavy-duty build quality from J Rockett. £105 delivered.
SOLD<a href="
http://imgur.com/ecUfSco"><img src="
http://i.imgur.com/ecUfSco.jpg" title="source: imgur.com" /></a>
Zoom MS-50G in very good condition, complete with box and manual. This is running v2 firmware which provides loads more effects. These are amazing units, capable of a huge variety of sounds and can also run on batteries.As well as more effects than you can shake a stick at, it also has a load of amp and cab sims so can serve as a very handy amp "backup" on your board.£55 delivered. SOLD
<a href="
http://imgur.com/z3EQoh2"><img src="
http://i.imgur.com/z3EQoh2.jpg" title="source: imgur.com" /></a>
<a href="
http://imgur.com/WMKRHWk"><img src="
http://i.imgur.com/WMKRHWk.jpg?2" title="source: imgur.com" /></a>
Pedaltrain Mini with soft case. This is the MkII version with the "channel" at the back and the wider space between the bars underneath to accommodate low profile power supplies. I'll also include my custom alloy channel fill strip (shown in the second pic) which means you can squeeze some extra pedals on the top row if needed. It just drops in the channel and is held in by velcro. Easily removed if preferred.£40 posted.
SOLD<a href="
http://imgur.com/Z84OF43"><img src="
http://i.imgur.com/Z84OF43.jpg?1" title="source: imgur.com" /></a>
<a href="
http://imgur.com/pUA39un"><img src="
http://i.imgur.com/pUA39un.jpg" title="source: imgur.com" /></a>
<a href="
http://imgur.com/wb8eVKO"><img src="
http://i.imgur.com/wb8eVKO.jpg" title="source: imgur.com" /></a>
I'm also selling a brand new, never used Planet Waves brown leather guitar strap. See separate post in the £Misc section
They sound as good as the insides are neat, which is saying something.
