It can if you do the tone-stack mod on the lead channel...
Actually no, but it does make that channel a lot more useful with more gain, a wider tone range and less fussy to dial in.
Heavy buggers, aren't they?
Enjoy your new purchase
Was not really my taste in terms of how it is voiced, if you keep the presence down it is not very bright thanks to some high end shelving in the pre-amp, sounded much better through a 2 x 12 compared to the combo, but the recap may have helped with that too.
You need to swap the whole tone stack (from before the .0022uF cap and 100K resistor to the output of the treble control) with the .01uF cap immediately before the master volume control, and move the feed to it to the bottom end of the 82K resistor (to compensate for the insertion loss of the tone stack in the new position, which otherwise makes the channel too quiet). The lack of the insertion loss in the *old* position also increases the overall distortion substantially, which makes it much easier to get a useful range from the volume and gain controls, rather than them both needing to be most of the way up.
