String gauge for C standard tuning
I'm am thinking of putting my guitar into C standard tuning but I don't know what string gauge to get. I currently use D'addario regulars on a 25.5" scale length, so I would like a similar amount of tension. I was also wandering if I'll need a neck or nut adjustment?
  • octatonicoctatonic Frets: 34318
    it will always be a bit of a balancing act between floppiness and string thickness- honestly C tuning works best with a slightly longer scale.
    Otherwise, I'd start with 12-60 and see what you reckon.
  • ICBMICBM Frets: 74494
    13-65 works perfectly for B-B baritone tuning on a Fender scale - obvious when you think what the B string in a normal set of 10s is - so 12-60 should be right for a semitone above that.
    You will need to widen the nut grooves and adjust the bridge saddles but otherwise not need to change much, possibly not even the truss rod.
  • Use www.stringtensionpro.com to find the nearest set, you can always substitute strings with singles as necessary
