Busy at the mo but if no takers then feel free to nag me. I can trace an outline as a vector and then you can scale to desired size with no loss of quality. How much detail: Body, scratch plate, vol, tone, jack, pups, . . . .
I have a pickguard template and a body drawing (on paper) that I made from one I had in for repair.
@notanon If you did have time that would be absolutely awesome! In fact, all I really need is that picture scaled up so the end of the fingerboard measures 57mm when printed out, I can do the rest from there :-)
(formerly miserneil)
Not 100% but pretty close
Just sayin'
Tsk. Scrub that then.
@Bridgehouse Na, ive alway been more Marriott than Doherty! That said, what's the body thickness on yours?! ;-)
And talking of Doherty... you know my olympic is supposed to be the one Doherty played on Up the Bracket?
thanks for the body dims....that IS thin!
Oh, and your target weight is the same as my Olympic - 4lbs 11oz
It would have a touch of neck dive if it was headless...
Alternately if you can tell me the dimension I'll scale it for you.
https://dl.dropboxusercontent.com/u/1508025/EpiTrace.pdf
https://dl.dropboxusercontent.com/u/1508025/EpiTraceOutlineOnly.pdf
