I've just bought this Gretsch 5122 with a bit of a ding in the side - I knew it was there when I bought so it's not a surprise but after some advice on the best way to fix it. The ding is a dent about 1cm round, it's pushed back the wood a bit but hasn't gone through the body. I will try and upload a photo later to make it clearer.
I was planning on filling it with sawdust (possibly maple to match the original wood), staining it then a layer off super glue over the top scraped back with a razor blade then micro mesh sanded.
I'm not too worried about making it seamless but want to repair it to protect it from spreading and make it look and feel a little tidier.
Any help much appreciated!
I assume laminate from the damage so would not be happy steaming.
Assuming it all feels solid I would be looking to fill that with a good quality epoxy dyed the same colour as the guitar, or a shade or two lighter before a final coat of lacquer.
I would want to avoid being invasive, but there are some good acoustic repair techniques which allow you to pull the wood back to shape first.... The issue here is access to the inside
Instagram
Football is rubbish.
I warm the bottles in hot water before mixing for a nice flow. You can tint it with a spirit based stain. If you mix it in a clear glass jar in small amounts you should get a good idea of the colour
Instagram
It might be a newbie but should the stain just be a wood stain? Or should it be an epoxy pigment?
Also should I fill to the top then fine grit sand and buff? Or would it be best to still top with lacquer?
