http://www.amazon.co.uk/gp/aw/d/B002QRYEBQ/ref=mp_s_a_1_1?qid=1459527233&sr=8-1&pi=SY200_QL40&keywords=silverline+pillar+drill&dpPl=1&dpID=41Jc2T3kr1L&ref=plSrch
I was never happy when using a hand drill I always had at least one hole that wasn't quite in the right place and scrapped more enclosures than I'd like to admit. Now it's dead easy and very quick to drill an enclosure and haven't scrapped any since I got it.
Mine is built like a tank and it cost me £60 a couple of years ago.
They're better than all the modern stuff imo
(formerly customkits)
i haven't tried it on enclusures yet but i made a solid hinged frame to hold screen printing frames this week and i drilled all the holes for that using the router so they were perfectly vertical and on the same horizontal. worked a treat and goes in a small suitcase box under the sink when not needed. an option.
Though there were some funny stories on the UK Workshop forum about people buying used industrial stuff, only to find that it was too big and heavy to get into their workshops. One chap had a lathe sink 6" into the tarmac of his drive.
Agree with that, you need a huge floor standing drill just to be able to have enough throat clearance to drill ferrules or string holes.
I just use a drill stand, it's OK but I burnt out all my Metabo's and Bosch's and it won't house my Makita as it's too small. The Silverline drill I got for £13 odd has so much out in the chuck it makes it ridiculous, but if you let it owner it does drill straight.
Obviously metal and other bits and bobs a pillar drill would still be handy. You can modify the stand with handrail fittings to allow enough throat to fit your body through.
Remember there are all sorts of jigs and frame you can makes for a drill stand as well as being able to flip the mount and mount it on an overhead C shaped frame jig, if you need a pin reference underneath for drilling both sides (Eg ferrules). But given the choice between a £100 pillar drill which I'd have to modify anyway and cheap drill arbour handle stand, which you can place on the body, the drill stand with a made up collet and a decent drill is better I would say and loads cheaper.
I've heard mixed things about Silverline pillar drills, Some say they are great for the money, some say the run out is so bad they are unusable.
I manage to make drill guides in oak for tremolos though with the stand. Drill furthest posts of the trem, fit the guide with drill bit pins in the holes and finish drilling the rest. Seems to work OK.
So in my mind you either spend £20, or spend £300 or search something decent second hand. If you do get lucky with a good silverline drill, it'll always be handy to have though for necks and stuff.
Bandcamp
