SOLD - 1969 Vintage Park 75!! -
Hi everyone - I have for sale a very cool amp - an original Park 75. It has KT88's as original and sounds awesome, somewhere between JMP 50 and Superlead/Super Bass. This amp has a master volume mod done by Rob Bonner, (a very well respected UK amp tech) which also includes a gain/brightness switch, which is very useful and sounds great as you turn it down. It's an easily reversible mod and there are no holes drilled if you want to put it back to stock. It has original transformers etc - it's possible that the power transformer is rewound. Lot's of original caps, some replaced. Gold Lion KT88's with JJ preamp valves. Parks are quite hard to date by the serial number but the cosmetics and date codes on the original capacitors put it at 1969. The cabinet, tolex and faceplate are in amazing condition for the amps age. The leather on the handle has frayed through but the metal reinforcement underneath is still intact.
Useless post I know but good luck with the sale,
Cheers
Hugh
www.proudhoney.com
