Me again, sorry to bother you clever tech types. I was just wondering as I'm looking at backup SS amps for gigging, what sort of volume drop an amp (specifically Fender FM100h) rated at 'minimum 4 ohms' would have going into a 16ohm 2X12 cab?
In theory I think it should be safe enough as it's an upward mismatch, but it's a 100 watt SS head and the only thing that could potentially put me off buying is a painfully low output from the mismatch - would this be an issue or would we still be looking at a negligible difference in output?
Thank you!
Does that look like the right sort of thing or would a flatter switch be better? I imagine it will be for sake of not getting knocked in transport etc.
If so I just need to find a wiring diagram and I'll be good to go - makes sense to install one so I can use the same cab, hauling around another one kind of defeats the purpose...
