Is there a better way...
RockerRocker Frets: 5105
... of securing a strap than using a shoelace to tie the strap at the headstock? Apart from fitting a strap button at the neck heel. Thanks
Nil Satis Nisi Optimum
  • richardhomerrichardhomer Frets: 24996
    No.
  • thomasross20thomasross20 Frets: 4468
    I'm considering fitting a pin to the neck heel. Is that OK or not....?
    The whole "string around headstock" thing is well weird to me. Some would say I'm the weird one.
  • ICBMICBM Frets: 74391
    The button on the heel is perfectly OK if you do it right. If the heel isn't a rounded (eg Gibson) shape where it can go on the centreline, you need to put it on the treble side about halfway up, you must drill a hole the proper size, and use a felt washer.
    On the back of the heel is generally a bad idea, the guitar will hang awkwardly on the strap and may not fit into the case as easily.
    If you don't want to do that, the shoelace is still the best way - but you can make it easier. This sounds odd, but... *first*, tie the lace into a loop, as large as you can make, and pull the knot as tight as possible. Then fit the loop to the strap by putting it through the hole and passing the rest of it through itself. (If you can arrange it so the knot is near the strap the next bit works best.)
    Then fit the whole thing to the guitar by pushing the loop under the strings, then pulling the whole strap through the loop befire attaching it to the button at the other end. This makes it much easier to get on and off than tying and untying a knot.
    Easier done than described :).
  • Winny_PoohWinny_Pooh Frets: 8060
    You can fit a strap button to the upper "horn" location as on an electric. You will need a small wooden block glued inside to take the screw.
  • SassafrasSassafras Frets: 30355
    You could always drill one of these into the upper bout and you wouldn't need the wooden block.
    edited May 2016
    Really, really don't even think about doing this unless it's a cheap plywood guitar you don't much care about.
    On a solid wood guitar there's a good chance of splitting the side even with a block on the inside. There is a reason you never see a button there on any good acoustic guitar.
    Repairing the damage caused by this is not a trivial job either...
    I'm tempted to NOT get a strap button fitted and just play acoustic sitting down!
  • LewyLewy Frets: 4498
    Or just use the lanyards with a quick release arrangement like Planet Waves make. I use them on all my acoustics and they work a treat.
  • WolfetoneWolfetone Frets: 1479
    edited May 2016
    I have never understood the wisdom of attaching the strap on the headstock. The maximum leverage on the neck joint is applied by the weight of the guitar. I will always fit a strap pin either to the heel or in the case of my EKO, into the neck reinforcement.
    Not even close - the string tension is around thirty times greater, at about 150lb for a set of 12s vs 5lb for the weight of the guitar. It makes no practical difference.
  • martmart Frets: 5213
    edited May 2016
    Another option if you have a strap button by the heel is to tie a string loosely from there to the headstock, running it through the strap. That way you can slide the strap along so that it's either nearer the head or nearer the heel, to get the best balance.
  • RockerRocker Frets: 5105
    Your 'loop' method seems a sensible method @ICBM. The guitar in question is not very valuable but I will hold off fitting a strap button on the underside of the neck heel (similar to how this is done on my Taylor).
  • BigLicks67BigLicks67 Frets: 774
    I use a couple of these :
    It's basically the same as the loop idea suggested by ICBM, but it's quick release and don't have to leave it on your guitar.
    I've been using them for over 10 years with no problems.
    I used the loop system as suggested by @ICBM and it works very well. Got rid of the untidy lacing and looks pretty good. Thanks for the suggestions guys, much appreciated.
  • octatonicoctatonic Frets: 34307
    Folk players did it so they didn't have to drill into their instruments.
    From an engineering point of view, I don't think drilling a hole in wood that has been bent into a curved shape is such a good idea.  I believe that there is a risk of splitting the guitar body as the integrity of the piece has been compromised.  I have not tried it myself and I could be wrong.....
    You're not wrong. That's why you don't want to drill into the body, even with a block on the inside - and because if the strap gets a tug, the block will twist slightly and the side of the guitar can split at the edge of the block instead.
    It's also OK on plywood guitars with thick multi-ply sides, like most semi-acoustic electrics have - but it's still not a good idea on a standard acoustic with about 3mm 3-ply sides - they can crack too.
    But drilling into the neck heel is not like that - although there are other pitfalls. If you don't drill the hole properly you can still split the wood, especially if you're drilling more or less directly into the endgrain, and you also need to be very careful to check that the heel isn't bolted on - if you hit the bolt (which can be very close to the surface on some) you're in a real mess… because you'll be left with an unusable hole that needs to be filled as invisibly as possible.
    You can probably guess how I know all of this :). Badly-fitted strap buttons are still one of the most common causes of DIY accidents, and it really puzzles me why more acoustic makers *still* don't fit a second button as standard.
  • bluechargeboybluechargeboy Frets: 1909
    I put a strap button on the heel of my Larrivee, no worries. I put some tape on the drill so I didn't go in too far and I checked on that internet and using my eyeballs that there were no metal components in the way inside. I probably made a small guide hole first.
    Just stop and think before you make the hole! You only get one chance. :)
    edited May 2016
    The point is that the wooden block internally is GLUED, and on the straight rather than curved part of the side.
    If you believe it's unsafe then let me link to my good friend Dan Erlewine:
