Whilst i am content on the guitar front one thing i have always struggled with is finding a decent amplifier. I am currently using a Blackstar HT-20 which is just not providing me with the sounds that i am after and my Mesa Studio 22+ is also not cutting (for me) the sonic mustard).
So i had a think about what it is i am after and it basically boils down to this:
a) A Blackface Deluxe style clean tone but has a amp based gain stage for rocking out;
b) Has an effects loop so i can use Tremolo, Chorus and delay effects;
c) Is not Twin or Mark heavy;
d) Can be used mic'd in a gigging environment;
e) Has a decent tank reverb.
I currently use a PRS Mira and an AV 65 Jaguar, and the style of music for the band i play in can be roughly described as following an alternative rock bent with elements of rockabilly/ surf/ punk.
Amps i have considered include Fender Prosonic, Mesa 5:25.
Budget would be £600 to at a real push £700...
So i guess the question to you fellow forumites is... what else is out there that might fit what appears my rather niche parameters?
![:D :D](/plugins/EmojiExtender/emoji/fb/4.gif)
Have to say don't I? The new Blackstar Artist .
I hefted one the other day, nowhere NEAR the mass of an Artisan 30.
6L6, said to be pretty loud. Two channels: Clean and cleanish. Voiced differently from other Blackstars and really designed as a pedal platform.
I don't suppose you would give a "tranny" van room* but the new ID Core 100 and 150 combos look very interesting?
*Mind you, I can see them becoming the go-to backup amp!
Dave.
Sounds like a 100w Fender Supersonic Twin fits your needs altho not many about. Switch it to 25w if you don't need it all.
Has the gain 1 & gain 2 settings on the burn channel for mean sounds and switchable bassman/showman setting for lovely cleans.
Nice reverb too. These don't seem to be much more expensive used than the smaller 22w version
Man, they are heavy though. Need the castors.
The supersonic twin is a real beast but I would not like to have to move it around, must weight 35 kgs or so...the 22w as it's smaller brother would be more portable...worth trying one out if you can. Shame, cos they only seem to be about £50 to £100 cheaper than the 100w
100w supersonic twin you can lift it with one hand but you wouldn't want to carry it very far. The castors are great but there is never an easy flat surface to roll across when you need one. Mine has celestion golds in it which probably helps with the sound colour. Not sure how they would compare to an everyday twin speaker set.
Not many about in single or twin variety so not easy to try one out. Gonna be one of those things where try stuff & will just hear the tone you want & that's it....you hit the target
