Carvin Vintage 33 tube amplifier in great condition for a 90s amp and in perfect working order. Covered in stylish lacquered tweed, the Vintage 33 utilizes a quad of EL84 power tubes and boasts a straight ahead control layout and two footswitchable channels. Sonically speaking, the Vintage 33's has crisp clean tones and there’s enough headroom in the circuit to maintain good clarity at higher volumes. The response is bright, even with humbuckers, yet with a quick twist of the tone knob it's easy to find the sweet spot with any instrument. Channel One can also pump out gritty distortion when turned up, and though the amp is quite loud in this configuration, the overdriven tones are punchy and snarling with good touch sensitivity. The full-sized Accutronics reverb tank is a welcome sight, and the textures it provides are smooth and airy with good decay characteristics.
Cosmetically, the amp is has signs of gigs but has been well kept, with little wear to the tweed, and a clean faceplate with white chicken head knobs, the Carvin logo is however missing and the grill cloth has some sagging. Fitted with a Celestial Vintage 30 from factory, the speaker sounds great and nicely worn in, but not worn out!
The original two-button footswitch and some paperwork are included.
£275.00 collected, from Nr High Wycombe HP14, but can courier for £25 extra
