FS Egnator Tweaker 15w Tube Valve Head ( Fender Vox & Marshall tones) - £225
skippy76skippy76 Frets: 625
Up for sale is a lightly used Egnator Tweaker, awesome little head selling as it doesn't get much use. Light home use only comes with the original box etc.
New these are around £330 so save yourself some money.
Powered by a pair of 6V6 power tubes, the TWEAKER will set the new standard for gigging micro amps. The gain, EQ and master sections each have a Tweaker switch providing a wide-range of tones from the ultra smooth and satisfying to fully over-saturated lead tones.
  • skippy76skippy76 Frets: 625
    The EQ switch lets you select from pristine American to classic Brit and even the elusive VX AC sound. The CLASSIC/MODERN voicing switch allows you to select either soft and smooth or hard and edgy power tube tone. It’s all in there to satisfy the ultimate "Tweaker".
    15 Watts All-Tube
    2 x 6V6 Power Tubes
    3 x 12AX7 Pre-amp Tubes
    Master Volume, Gain and 3-Band EQ
    Modern/Vintage Amp Voicing Switch
    Buffered Effects Loop
    Selectable AC, British and American Tone Controls
    Clean/Hot Gain Selector
    Tight & Bright Voicing Switches
    100V / 115V / 230V Switchable
    Output Power: 15watts RMS Cathode Biased
    Input Impedance: 1meg Ohm
    Output Impedance: 4 Ohms, 8 Ohms Or 16 Ohms Switch Selectable
    Tubes: Two Egnater Premium Selected 12AX7Matched Pair Of Selected 6V6GTA
    Vintage/Modern:+4db @ 120hz, +4db @ 3.6KHz
    USA/AC/Brit: Selects American, V-X, British Tone Stack
    Clean/Hot Switch: +9db Gain Boost
    Tight Switch: -6db @ 180hz
    Bright Switch: +8db @ 4khz Max
    Dimensions: 14” (W) X 8” (D) X 7.5” (H)
  • pruddprudd Frets: 692
    great little amps these, ive owned a head and now have the combo, both punch well above their weight.
    Weekend Bump
    Bump would consider taking a part ex on an Angry Charlie pedal
  • Where are you based?
    edited June 2016
    Hi mate,
    Based just off J7 M25, so you're not too far away in Chichester (I got married down that way  ages ago!)
    Bump, £200 collected
    Cheers
  • BahHumbugBahHumbug Frets: 352
    Pm'd
    Sold thanks
