Installing and SSD and Unbuntu on an old laptop
danodano Frets: 1647
I'm sure I've seen this covered in a previous thread but can't find it for the life of me...
I have an old HP laptop (from about 2009) that I don't use.  Im thinking of installing unbuntu .
The existing hard drive has some problems from whatvi remember so inplan to swop it for a SSD.
My question is once I put in a new SSD how easy / hard is it to install a new the new OS ?
Anyone experience of doing this?
  • monquixotemonquixote Frets: 18329
    Should be fairly easy provided your laptop doesn't have any weird hardware.
    Just boot from a DVD or USB stick
  • Hertz32Hertz32 Frets: 2248
    Make a bootable image of Ubuntu on a USB/DVD.
    Swap HDD for SSD
    Boot laptop with image inserted
    Boot from image
    Install OS
    It *should* be that simple. But I haven't done it since 12.04...
    'Awibble'
  • hotpothotpot Frets: 846
    I put Ubuntu 16.04 on a couple of oldish desktops & they run better than they ever did/
  • Axe_meisterAxe_meister Frets: 4858
    Couple of things to check first. Is the hard disk SATA or IDE?
    if IDE you may have difficulty sourcing a drive.
    2009 vintage will only be SATA 2 do not the best performance
  • danodano Frets: 1647
    Thanks for the advice. I'll open it up this weekend and check the exact HDD format.
