I am going to drill two extra holes in the top of my Jackson so i can fit two extra pots. There's tons of space as i have the 'Large' control cavity but what i'm stuck on is how to drill through the paint without splitting it.
I can vaguely remember someone telling me you put insulating tape over where you're going to drill but it's a vague memory at best.
Should i drill the hole from the rear inside the cavity through to the top, or from the top through to the control cavity ?
Should i drill a smaller pilot hole or will the drill for the hole size just go through without a problem ?
Any tips would be great.
Thank you guys.
@John_P
I was thinking through from the top as well for the same reason but wasn't sure.
@Roland
A Masterclass !
Thank you sir, that will see me right and very informative.
Brilliant, thank you.
