Drill Advice
I'm planning to buy a drill in the next few days so I've been looking around on t'inferwebz.
It's mostly going to be for DIY and assorted jobs around the the house. I've noticed a hammer drill is literally a couple of quid cheaper but, not having a clue what a hammer drill is or what it does, do I need one? A hammer drill that is :dizzy:
Advice much appreciated thank you please
Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
«13
  • SporkySporky Frets: 30216
    Hammer drills pulse the bit in and out as it goes 'round; this is useful for drilling into brick and stone.
    Good bits in a mediocre drill will get you much further than mediocre bits in the best drill in the world.
  • NiteflyNitefly Frets: 5069
    Depends what you're going to drill into - if ypu're going into masonry (brick or blockwork) you need a hammer drill.
    Basically it "hammers" the drill bit into the material at the same time as drilling.
    For occasional use such as you decsribe you'll be fine with the usual Black & Decker / Bosch / Makita rechargeable stuff.
    Have a look at Screwfix and Axminster Tools - they quite often have deals on.  I got a nice Bosch set for £65 from Axminster, power-driver and hammer drill in a case.
    Bah - out-sporked again!
  • TheBlueWolfTheBlueWolf Frets: 1536
    Ah that's gonna be handy should I decide to drill into my walls. Decent drill bits have been added to my shopping list!
  • professorbenprofessorben Frets: 5106
    In all honesty there not much between, Makita, Bosch and DeWalt.
    The main choice you have is Batt or mains.
  • SambostarSambostar Frets: 8745
    Get a Makita DHT458 bare unit and a DTD146 bare unit.  Get a 3.0 or 4.0 Ah battery and a charger and a spare battery or two when you can afford it.  Work it out from ebay sellers, it's usually cheaper, the bare units are around £60 each, fast charger as low as £34 and a 4.0 Ah battery around £50
    Backdoor Children Of The Sock
    You can get nice Drill/Driver and Impact driver sets these days for good money from the main brands.
    Thr only thing I'd say is steer clear of the Own Brand drills from the DIY stores.
    The torque on the Makita 458 will tear your arms off.  If you need an SDS drill to go through 1940's concrete, get a cheap Titan one from Screwfix or something and use it until it breaks, much better and cheaper than a hammer drill..
  • ThorpyFXThorpyFX Frets: 6329
    edited July 2016 tFB Trader
    What's your budget? I found that I bought cheap drills in the past only to have them break within a year and have to rebuy. I spent marginally more on a Bosch professional cordless without lithium batteries and haven't looked back. Two batteries is very useful too.
    One like this actually.
    http://www.screwfix.com/p/bosch-gsb-18-2-li-plus-18v-4-0ah-li-ion-cordless-combi-drill/7434k
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
  • paul_c2paul_c2 Frets: 410
    If you're looking around the £100 range then the likes od DeWalt, Makita etc do models but they're not the same as their £400 models!!! Hammer action is definitely worth having for masonry/brick but when cordless is handy and its too small a job to justify an SDS drill etc. 2 batteries is definitely worthwhile - charge one while you use the other, no need to stop working. And go for Lithium battery not Ni-Cad. Also 2 speed is handy.
    I bought a Hitachi which has all the above for £100 (including 2 Lithium batteries) and its still going strong.
  • boogiemanboogieman Frets: 12902
    I've had one of these for a couple of years, pretty happy with it.http://www.screwfix.com/p/dewalt-dcd776c2-gb-18v-1-3ah-li-ion-cordless-combi-drill-xr/17648
    If you go cordless, definitely get something with two batteries, Sod's law says the battery will always die at a crucial moment.
  • ChalkyChalky Frets: 6813
    Bosch 18v cordless hammer drill/screwdriver has never let me down.
    I'm thinking £100 to £150 in terms of budget. It's tempting to get a cheap own brand but I'm wary of them being unreliable and needing to be replaced in which case I'd rather get a decent drill up front.
    I'd prefer a cordless drill so I'm not arseing around with leads in which case I'll have a spare, charged, battery handy.
    Cheers for the tips guys, I'm going to check out the linkage that's been offered :)
  • chrispy108chrispy108 Frets: 2336
    I can't see the point of cordless for DIY. I can't be more than 10m from a plug socket in my own house, so why add the hassle of charging batteries and then dealing with them going flat etc?
    I'd get an impact driver: https://www.howetools.co.uk/makita-td0101f-240v-impact-driver-6-5mm-hex
    then a decent sized drill.
    Drill for holes, impact driver for screws.
    The lead always seems to get in the way or drag with a corded drill, it also adds weight. Drilling above your head is enough of a PITA without a lead in the way.
  • randellarandella Frets: 4732
    edited July 2016
    It depends on what you're drilling. My house's outer walls were built from brick that more closely resembles cut diamond, I can't tell you how many (decent-quality) masonry bits I've been through. I've killed 3x 18v cordless drill batteries and counting; only a corded drill is any use if you need more than two holes without recharging.
    The inner skin, however, is made from blockwork the texture and hardness of Cadbury's Wispa. I cut a recess for a dimmer switch pattress box in ten minutes with a cordless drill and an old, blunt wood chisel.  Go figure.
    Depends on the drill and the bits.
    I have a full-sized SDS mains drill; it cuts slower than the cordless 18v SDS Bosch with the same bit, and the Bosch is smaller and lighter. The Bosch did 30-odd holes in brick and concrete (and it's 50s brick and concrete which is like granite) on a single battery, with charge remaining.
    One of these - http://www.axminster.co.uk/bosch-gsr18v-ec-fc2-set-combi-4-attachments-18v-4-0ah-102121
    Marvellous bit of kit.
    edited July 2016
    At four times the price of my cordless drill, I would hope it is!
    In seriousness, the way I see it is cheap corded drill + minor inconvenience = more money for overdrive boxes and beer.  :)
    The block I live in has been around since the early 70's, possibly longer. I can't see myself doing a *lot* of drilling into the concrete walls, apart from a few places to hang guitars and I share the sentiments of @boogieman in not wanting to be bogged down with cords
