bear with me!
So i just plugged in and heard a slight crackle from my amp (Rivera R30) and so i thought i'd give the tubes a tap to see if one had gone microphonic, they all sounded normal. I sat back down to play and as soon as I engaged the looper on my timeline the volume dropped massively and I got an electric shock. This is super weird as the tubes sound fine and I've never had anything like this before. The only thing i can think is that i've since incorporated a pedal which has a ground lift, though I don't have the lift engaged.
Anyone got any thoughts?
Hard to say since I don't know what your local techs charge, but if it was me I would say unlikely to be much under £50 if there's any major dismantling involved to get to the parts, and probably not over £100 unless some multiple failure has happened.
