Tuning using mobile phone
djspecialistdjspecialist Frets: 946
Can anyone recommend a way to use an Android app for tuning an electric guitar, in a noisy environment?
I have a couple of apps installed (Boss Tuner; DaTuner Lite) which are OK - but since they are listening via the onboard mic, they only work well in quiet situations.
Would plugging the guitar directly into the phone (via an adaptor which connected the signal to the appropriate pole on the 3.5mm jack) work?  If so where could I get such an adaptor?
Or do I need an interface?
Trading feedback | FS: Nothing just now
JM build | Pedalboard plans
  • I think you can download a TC Electronics tuner onto your phone as an app.
  • ICBMICBM Frets: 74470
    You can, and it's excellent, but it still struggles in a noisy environment for the above reason.
  • Tuners are so cheap these days that faffing around with a phone isn't worth it. Reverb were selling a clip on tuner for £2, similar deals available on eBay.
  • EricTheWearyEricTheWeary Frets: 16666
    If I need to tune up using my mobile I call up Tom Jones and ask him to sing a perfect A down the line.
  • fretmeisterfretmeister Frets: 25557
    Needs an interface.
    Even clip ons are a bit crap at noisy gigs as the guitar body vibrates from other noises. Get a pedal.
    That's my approach too. I have the TC Polytune app, and it's absolutely brilliant for tuning at home where it's far less hassle than having to plug in a tuner or even to clip one onto the headstock - and for setting up guitars, where it's possibly the most time-saving thing I've ever spent £2.99 on… especially when tuning up guitars with floating trems or classicals, where everything constantly goes out until it all settles down. You just strum away and keep tuning until it all settles down. It saved me more than £3 of labour time the very first time I ever used it.
    But it's crap at gigs or band practices, even when you put it right in front of the amp's speaker - and that means you have to tune aloud anyway. That's why I still own a couple of Boss TU-2s and have no plans to replace them - other than possibly with TU-3s eventually, the display is better.
  • SassafrasSassafras Frets: 30357
    That's the only advantage I can think of for using a mobile instead of a dedicated tuner.
  • vizviz Frets: 11041
    edited October 2016
    N-track tuner is good because it shows you a graph of the whole frequency range with your note showing as a spike
  • JD50JD50 Frets: 670
    Irig?
  • Or you could just get a guitar that tunes itself. Like a Gibson
  • KKJaleKKJale Frets: 993
    edited October 2016
  • Strobe tuners work best in a noisy environment (within reason!) because they effectively ignore the noise. This is even more pronounced with a mechanical strobe tuner.
  • TheMarlinTheMarlin Frets: 8499
    I use Cleartune.  It's by far the best I've tried.
  • DLMDLM Frets: 2529
    edited October 2016
    Tom Jones sees @EricTheWeary's number in his display again:
    http://i.makeagif.com/media/10-04-2016/58TLnk.gif
