If the pickups are held in with woodscrews which pass through the holes and into the wood, it's done wrong - they should be fine-threaded machine screws which engage with the plate. They do go through into the wood as well, but that's not what holds the pickup in place. The treble-side hole has no wood under it anyway.
The two screws in the neck pickup surround don't look right, they look more like they might be woodscrews.
Wonder why they changed to doing it this way? It's got PCB controls so maybe a time saving exercise
The larger size of the modern plates will probably save a bit of time by making it much easier to centre them in the cavities.
