New TC Electronic mystery pedal
  • thecolourboxthecolourbox Frets: 9713
    edited October 2016
    I think we can assume it's a new range of pedals in this format, I reckon as follows:
    First will be called a Furr Face - it'll add a stupid grotty looking hispter beard to your tone
    Another will  be called the Jack Up - hence the jacks on the top side of the pedal, this reduces the trouser length of your tone by the required 0.75", to partially display your tone's jazzy socks.
    And the last, for now, will be a completely transparent pedal, with true bypass, and a mix knob to mix in your clean tone with your transparently unaltered clean tone.
    More to follow
    soundcloud.com/thecolourbox-1
  • I havent seen a USB socket yet (unless i have totally missed it!) Maybe its not a toneprint one???
    ...or it could be a new Toneprint range which no longer requires a USB port for firmware updates and deep editing?
    Then again, the Toneprint pedals all tend to have the same number of knobs (or thereabouts) because the hardware is more or less interchangeable.
    100mA is an awful lot for most non-digital pedal types, although all except the Minis draw more than that (the Flashback is about 250mA, as I recall).
    <space for hire>
    Other thought: when tc got bought out by the owners of Behringer there was much speculation what that might mean. So, Chinese made cheap tc range? Non toneprint delay, reverb, etc.
  • Other thought: when tc got bought out by the owners of Behringer there was much speculation what that might mean. So, Chinese made cheap tc range? Non toneprint delay, reverb, etc.
    Yeah maybe that's quite possible. Some of the Behringer pedals actually sounded OK but would break if you stepped on them, so if TC could do them with better switches.... Oh hang on
    6reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    I've never had a problem with any TC pedal.  Having said that, I haven't really kept any of them long enough lulz.
    This looks like TC are launching a new series of analog pedals or something... something totally unrelated to everything else they do.
    My Flashback X4 died on me. Ended up having to get a replacement from Gear4Music. All went fine, but there was no real indication of what went wrong.
  • PMT just insta'd a photo suggesting that they are releasing three new analog pedals.
    Dont know why I am getting caught up in the hype, I have never owned a TC pedal!
  • Gassage said:
    Sassafras said:
    While TC are carrying out this long, boring teaser campaign, half a dozen new pedals have been made available in shops by other manufacturers.
    I've changed me rig 14 times in this period alone. They missed out.
    is that a euphemisim....?
    My flashback X4 is going to last for years, absolutely no chance it will fail.
    its still currently under confiscation.
  • Yellow is overdrive I bet.
  • Blue chorus
    green flange.
  • Thinking about it...they all seem to be 100mA. That would suggest one of two possibilities:
    1 - They're all based on the same platform, ergo some sort of digital stuff
    2 - TC couldn't be arsed figuring out the actual current draw, so they just put "100mA" on the back and hoped nobody would look too closely.
    <space for hire>
    Either way TC need to get a new photographer, you can't even see what the pedals are!!!!!
    #artforartssake
    You mean like a Nuenaber type interchangeable pedal, where you buy say, an overdrive, but a quick TonePrint burst from your iPhone turns it into a reverb?
    Id be over that like a UKIP MEP at at fistfight.
  • I could recommend a photographer....... ;-)
    I think the pedals will come in various platforms - you will have an overdrive / distortion platform, flanger / chorus platform, reverb / delay platform.  With each platform you will be able to download a new type of distortion, flanger, chorus, delay etc and load it onto your pedal which relates to that particular effect.
    And it's...an analog delay! 3 knobs, that's yer lot.
  • stickyfiddlestickyfiddle Frets: 26964
    edited October 2016
    Not just a delay...
    Echobrain Analog Delay
    Afterglow analog chorus
    https://www.youtube.com/watch?v=MV4AoUsnZQY
    I'm guessing there's more to come.
  • monquixotemonquixote Frets: 17603
    Not impressed.
    Brings absolutely nothing to the party.
    I'd rather have one of the Boss Waza pedals (or an MXR) based on their much better reputation for reliability.
  • The chorus sounds pretty good, but the Echobrain and Grand Magus are instantly forgettable to me.
    <space for hire>
