http://www.guitarelectronics.com/product/WD2HH5L11_06/Guitar-Wiring-Diagram-2-Humbuckers5-Way-Lever-Switch1-Volume1-Tone-06.html
The switch wiring is as follows:
A B C D
E F G H
A and H are the rotors and are connected to the pickups - A neck, H bridge. C, D, E and F are all connected to the volume control. (This is basically the same as standard Tele wiring on a 3-way up to this point.) B is the neck coil split and G is the bridge coil split.
Do I need to get powerpoint out for another diagram @ICBM ?
Although it's basically just this
http://www.guitarhq.com/67tele.gif
With each pickup's coil split connected to the terminal next to its own hot wire.
https://sites.google.com/site/phostenixwiringdiagrams/home
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
