Football is rubbish.
The quality of the guitar, pick-ups, taper of the pots, capacitor values and 'treble bleed' mods all make a difference though
However it makes less of a difference on saturated gain levels and 'processed' amps/pedals
If you start with the setup and the guitar on 10, then everything else becomes a 'cut' as though you are loosing something when you turn down vol and/or tone pots - so change the approach so that 6/7 is the norm and 10 becomes the boost
It doesn't bother me, but my full tilt signal is quite bright so it cleans up to being warm and even, rather than muddy.
Might need to dig in, adjust vibrato/ picking hand a bit but I quite enjoy doing that.
Cheers
Hugh
www.proudhoney.com
The only issue is choosing the value of the capacitor. PRS use 180pF which is probably a good starting point.
The pedals I use tend to work with this set up. My Sunlion, OCD and my AC Booster all react well with the guitars controls.
