P90 experts - step this way!
I currently have a guitar with a single coil in the neck (6k ish i think) and an Oil City Blitz in the bridge. I've had a bucker sized P90 sitting around for ages (vintage vibe guitars) that has a reading of just over 10 and I'm thinking about sticking it in the neck position instead of the Strat pickup. The thing that is stopping me is the potential vol difference because of the output difference, but I'm wondering if simply setting the P90 quite low will counteract this enough so that the difference isn't that noticeable. I've never had a P90 before, so am I on the right track here?
  • SassafrasSassafras Frets: 30358
    I seem to remember reading that a pickup's resistance wasn't a reliable indication of it's power but I may be wrong.
    I think inductance is a truer measure of their power.
    As you can tell, I'm not really up on electronics.
  • WezVWezV Frets: 17499
    try it, there are no incorrect pickup combos.
    yes, it might make it hard to balance volume but you can get close by adjusting heights.  I like a humbucker in a tele neck position.  You generally notice the tone difference more than the volume one.
    also, vintage vibe p-90 sized humbuckers were the first custom pickup I used about 12 years ago.  DiMarzio, SD's and the other usual suspects before, U.K. Made swinesheads and bkp's shortly after.... Totally non standard construction but I remember them being pretty good
  • I'm considering going for a rewind, which shouldn't cost the earth, and that way I can get exactly what i want, which would be a '50s type wind. I'm going to give it a crack in the meantime as it might just work nicely off the bat. As @Sassafras says resistance is not a perfect guide, but I'm pretty sure that what I have will be pretty meaty, so it'll be a bit of fun even if it's not a long term solution ;-)
  • 57Deluxe57Deluxe Frets: 7406
    P90s pack far more punch than Fender Strat style single coils
    <Vintage BOSS Upgrades>
  • I love P90's they are great, like a Strat single coil but a lot fatter and with more bite.
  • I just got my first guitar with P90s and to be honest I'm blown away. All the clarity and bite of a single coil with all the midrange punch and growl of a humbucker, they don't even seem that susceptible to hum which I was worried about. Maybe it's just because the guitar already had some Booteek hand wound jobbies installed, or maybe it's just the honeymoon period that goes with all new gear, but I'm impressed.
  • OilCityPickupsOilCityPickups Frets: 11991
    With a DCR of over ten your HB sized P90 is wound with finer wire than a normal P90 ... you simply can't get 10k worth of 42awg wire in a humbucker cover. Therefore its DCR is no indicator that it will be louder than your Bliitz Spirit ... around 8.5k with 42awg wire. It will be a bit quieter if anything (and a bit more compressed because of the wire gauge). I would hazard a guess that it's been wound with 43awg to keep close to the 10,000 turn P90 'sweet spot'.
  • I currently have a guitar with a single coil in the neck (6k ish i think) and an Oil City Blitz in the bridge. I've had a bucker sized P90 sitting around for ages (vintage vibe guitars) that has a reading of just over 10 and I'm thinking about sticking it in the neck position instead of the Strat pickup. The thing that is stopping me is the potential vol difference because of the output difference, but I'm wondering if simply setting the P90 quite low will counteract this enough so that the difference isn't that noticeable. I've never had a P90 before, so am I on the right track here?
    You are spot on, sir, and thanks for the info :-) His site says 9,500 turns of 43awg. I've no idea what magnets it has, but I'll give it a crack and see how it goes. If it's too hot for my liking, it'll be coming your way for some changes in a month or so. Thanks Ash :-)
  • metalemetale Frets: 57
    I've had a neck humbucker-sized P90 (6.9K awg 42, alnico IV magnets) overpower a bridge humbucker (9.4K awg 42.5, alnico V magnet).
    Tweaking heights never got me there, so had to split them: coupling the P90 with another P90 and the humbucker with another humbucker.
    P90s are pretty punchy, and I think it has much to do with the double magnet design.
    Note: the P90 did balance well with another bridge humbucker (14K awg 43, alnico IV).
