There should be a blocking cap on the input stage of the wireless but it may be faulty.
Thanks @ICBM
Is this blocking cap inside the unit? Not something I should tamper with? There's nothing externally near the input. Could this damage my amps with continued use? If so I'll stop using it.
Not sure if it's the same issue, but it's always been noisy(extremely) with my Suhr Rufus Fuzz, so I stopped using the Fuzz with the wireless almost instantly. I did assume that was due to the nature of simple Fuzz circuits though and that Fuzz + Wireless = Noise.
I'm not used to these things I guess I didn't notice this latest issue until it became apparent to me, didn't register at first.
I have grounds to return it to manufacturer you reckon, it must be faulty?
Thanks.
Probably not unless you're handy at fairly small-scale electronics repair!
No. The only effect will be on the guitar volume pot, and even then it won't cause any damage, just make it noisy.
Possibly - depending on how the fuzz is designed. It may simply be that it doesn't like a low-impedance source connected to it - the wireless receiver is one.
Possibly - a DC leak from the input which makes the guitar volume noisy would count as a fault to me. Whether it's serious enough for them to admit that and replace it, I don't know. It's also possible that a replacement unit could do it too...
I'll contact them
