Cat in the attic?????
  • cj73cj73 Frets: 1003
    We've just got two kittens and they make bird like sounds to each other......
    Just saying
  • and the silver spoon, little boy blue and the man in the moon.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • RobDaviesRobDavies Frets: 3090
    I prefer homes under the hammer.
  • Homes Under the Hamster?
  • Ready Steady Cockatoo
  • Star Wars - The Cat Awakens
    The Dogfather
    Catbusters
    I'm here all week do try the veal etc.....
    Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
  • Have I got miaows for you?
  • Guitar_SlingerGuitar_Slinger Frets: 1489
    edited December 2016
    Starskey and Rabbit Hutch.
  • How come nobody's said Only Fools and Horses yet?
  • crunchmancrunchman Frets: 11519
    ICBM said:
    I hope you didn't put the old smoke alarms in the bin - the reason they have a life span is because the detector uses a small radioactive source, which decays over time. They need to be properly recycled - or at least disposed of somewhere that takes hazardous waste.
    If there is a life span for the device, it's probably not caused by the radioactive source. Google suggests that the isotope normally used is Americium 241 which has a half life of 432 years.  There won't be a significant drop over 10 years.
    There is very little of it in a smoke detector - typically 3 micrograms.  It's also an Alpha emitter so it's not going to be all that dangerous unless you ingest it as alpha particles are stopped by skin.  Even if you ingest it, it's used in the form of an insoluble oxide in smoke detectors and will just pass through.  In the normal way of things Alpha emitters aren't that dangerous unless you put a much more active isotope like polonium 210 into someone's tea!  As long as you don't upset Putin too much you should be ok.
    There is a much higher level of radiation from an old style luminous watch dial.  There are probably millions of them in landfill.
  • scrumhalfscrumhalf Frets: 11429
    Only Fowls and Horses, surely.
