I bagged a body and neck from GSPBASSES - and did a bit of a build thread over in Making & Modding.
Now it's (nearly) done, I thought I'd post the results here - seeing as it's a new guitar to me, and my first Tele (!?!)
It's an obeche body and maple/rosewood neck - and it's 6lb 4oz dripping wet..
All the parts are cheapo no brand from Allparts or the like, and the Nitro is courtesy of the wonderful
@SteveRobinson ;
I relic'd everything from pretty much brand new - some parts I'm really pleased with - others not so much. The whole thing was a learning and experimenting exercise, so it's been really really useful.
I have to get a string tee for the E+B and the nut needs a bit of filing - other than that it's done.
I'm considering lacquer checking it but I need to wait for the nitro to harden before I do. Should I do it, or leave as it is?
Here you go:
What's going on with the saddles?
Let it gas off for a month then get it in the freezer! Authentic checking ahoy :-)
(formerly miserneil)
Daphne Blue indeed!
Also, after checking I will prob do a little more light relic'ing as I'm trying to do the damage in the order it would have happened naturally.
I'm not actually expecting this one to turn out that well TBH as its a proper test bed - things like egg white as grain filler, vinegar for acetic acid ageing and a whole variety of implements and stains for the wood.
The most difficult bit is the obeche - it's like balsa and squishes very easily - in an unnatural way compared to ash etc..
I will go slightly further. Mine is definitely going in the freezer, and I just sprayed a coat of tint over the blue with the hardware in place
Instagram
I will freezer and then reassess I think!
Looking forward to seeing yours!
Whats the relevance to the freezer...is that how you relic laqueur checking?
The freezer is to contract then rapidly expand the lacquer finish - actually the most effective way of doing it is hair dryer then a super cold blast from a fire extinguisher. However freezing then hair drier will give a good subtle effect..
freeze sprays will check it, but it will look more like old pottery than guitar lacquer
Instagram
