Amps That 'Bloom' - Which To Buy ?
WazmeisterWazmeister Frets: 9708
Ok, as most of you know, I've tried a lot of amps.
I currently own a Carr Rambler and a Lazy J20 with extension cab.
The sound that I am after is from an amp that 'blooms'; now, what do I mean by that ?
It is the sound of an amp that is maybe slightly clipped, with harmonic overtones, almost (almost) suggesting feedback.
For example, this Redplate clip below at exactly 10.52 onwards. It is also heard throughout (5.46 onwards);
I have definately heard this in a Redplate, and maybe the Mesa King Snake.
Is it the Dumble thing ? Does an effects loop cause this ? Are these amps almost compression free ?
Over to your thoughts and wisdom folks :)
«13456
  • Marshall MG 15
    9reaction image LOL 0reaction image Wow! 5reaction image Wisdom
  • hotpickupshotpickups Frets: 1823
    edited December 2016
    Louis Electric KR12 actually has a 'Bloom' knob on. There's one in the classifieds now
    http://www.thefretboard.co.uk/discussion/91252/louis-electric-kr12#latest
  • Im after those natural 'blooms', which just do not come from a pedal, and only from the amp.
    Yep that'll be it check it out. Amazing amps
  • I'd suggest there's quite a lot of gain in the there and he's sitting virtually on top of the amp - so harmonics seem to start feeding back pretty easily.
    The overall character reminds me of the Fuch ODS I once played - which is very much in Dumble territory.
  • BidleyBidley Frets: 2952
    Try TGP.
    1reaction image LOL 0reaction image Wow! 6reaction image Wisdom
  • i'm not i know what you mean by bloom - on the clip you posted it just sounds loud and very close to the guy sat on it, hence it wants to feedback when not being played.
    Is it something more specific tonally, or just that feeling of it being right on the edge ?
  • RandallFlaggRandallFlagg Frets: 14007
    Victory V40 with a good drive pedal, both turned up loud. It's just a strong midrange sound with the guitar close to amp feedback
  • ThePrettyDamnedThePrettyDamned Frets: 7507
    Yes, all of this - that's a moderately loud amp right next to the guitar send you're hearing feedback.
    Bloom was described technically by someone on tgp and it's a function of an amp.
    If I remember correctly, and I may not, it comes from a valve or valve emulating rectifier under particular conditions where it sags quite heavily. If you've maxed out a jtm45, you'll know this - it's really annoying unless you want it there
    So basically, if you want what's in the video, I think you need soundproofing and ear plugs. Find an amp you like and, get close and turn it up with some gain. In my opinion, of course.
  • As an aside, that amp sounds a bit like a boogie to me. I wonder if dumble amps have anything in common?
  • ToneControlToneControl Frets: 12093
    Ever tried a  hollow body Suhr or Tom Anderson with a  50w or 100W  clean amp turned up loud?
    try to find 2 compatible opinions on the definition of bloom:
    http://www.thegearpage.net/board/index.php?threads/describe-amp-bloom.369114/
  • richardhomerrichardhomer Frets: 24865
    Yes - up to the MkIV, the 'lead' channel was a further cascaded gain stage which was switched in.
    The Dumble OBS was exactly the same. Several Two Rocks operate in the same way.
  • So basically, if you want what's in the video, I think you need soundproofing and ear plugs. Find an amp you like and, get close and turn it up with some gain. In my opinion, of course.
    I get your meaning, but the point for me is that the amp needs to produce this at 'realistic' volume levels
  • My Fuchs Four Aces did that bloom in to feedback thing. Got to that point quicker and with less gain than any other amp I've played. No idea why though which isn't much help!
  • Amp Bloom = Emperors new clothes
  • WazmeisterWazmeister Frets: 9708
    No mate, Ive got to say your wrong - unless I have my terminology wrong !!
    I have definitely  felt and heard this in some amps ive tried, and not others.
    I'm with you @Wazmeister well at least I've experienced it. Quite recently in fact
    On which amp mate ?
    On which amp mate ?
    Louis Electric in my case it was the Buster.
