Bandcamp
Spotify, Apple et al
All these compared with the same drummer and usually the same bass amp, so I think it's reasonably fair. The ones that were the hardest to work with were the JTM45 because it was too mushy and didn't really cut through, and the Super Lead because it was so over-the-top. Which is not a reflection on Marshall in general, just those two really - the 2204 was great.
The reason I ask is I am hoping to get more cut through than I currently have.
It's still a lot punchier and louder than an 18W or 5E3.
it is easily changed by someone who knows what they doing, but straight out the gates it might just not be the amp you are after. you really have to try one at gigging volume if you can.
Its a giggable amp for sure. Sounded epic with a Bogner Red up it. Much better than the '59 Bassman RI I had.
That Fender was a loud amp. Very punchy and not quite as brown as I'd hoped actually. And also very awkward to attenuate because of how the speakers were connected.
You won't need anything else.
Cheers
Hugh
www.proudhoney.com
Hugh do you use any attenuation on your Park? That's non mv isn't it and basically a 1987x. We you way way too loud at gigs?
For the biggest change you actually want the worst quality rectifier valve you can find
You should re-bias too, or the power valves will be running cooler.
I play loud, I always have, never used attenuation and never will. I don't really care for 'too loud'. What is that? Always wondered why folk want a polite sound, give it stacks dear boy, we have a long time to be quiet....
Cheers
Hugh
www.proudhoney.com
Have a read through this
https://legendarytones.com/eric-clapton-appreciation-early-years/
In your first post you wanted more volume and less compression, another post you describe your tone as Classic rock 60/70 and another post you want more cut, so if that's what you want then a 1987/jtm50 the with a rockcrusher attenuator would be ace.
use the bright input for more cut, use the normal input for more bass content and warmer tone.
Tone me wise the 1959 slp up full is my all time favourite sound but I am almost positive that I would not get to use one at any stage that I play.
You can also get away with fitting them with 6V6s if you use decent ones. That will drop the power to around 25W even without attenuation.
