Cheers
https://www.gak.co.uk/en/fulltone-fulldrive-2-mosfet/50464
Buy a TS Mini and a Boss SD-1 (to use as the boost).
Ok it's two pedals instead of one but I really do find using an SD-1 as a boost for my other drives is the perfect solution
OR JUST GRAB A MOLLER!!!
Cheers guys, those both look interesting.
I understand that the TRex Moller has an independent boost which could be v handy. @builttospill - does the Fulltone boost work independently?
Cheers
I'm actually using two pedals at the moment, a Joyo Vintage OD (TS clone) and Joyo Sweet Honey as the boost. I like the sounds I get, but they can be a bit noisy together and an all in one would be easier for gigging + I can't stop buying pedals
If you fancy it drop me a pm after NYE and I'll send it down as a loaner
Wow that's a very kind offer, i'll bear that in mind! You sound rather definite about no more gigging, had enough of it?
A flatter mids overdrive is another possibility (and often gives the ability to sculpt the tone a bit more than a boost- I might want a flatter response than a TS but the ability to cut the low end is still often pretty useful)- something like a timmy, soul food or something like that.
you know that's probably a pretty decent combo. aside from the possibly questionable reliability of the joyos (mine have been fine, but i've heard some complaints) there's no guarantee that what you buy, even if you spend a lot more, will sound all that much better...
Another OD I have yet to try but has independent OD/Boost is the Diamond J-Drive MK3
Another OD I've yet to try is the Diamond J-Drive MK3 it has an independent clean boost which is supposed to be really nice.
