Storing guitars/guitar stands
BarneyBarney Frets: 628
Im looking for a stand the will go along a wall and store all my guitars ...either in the cases or just the guitars...i have a room and they are just in cases on top of each other ...so i struggle when i want one from the bottom...just looking for a neat storage solution really but with easy access..
  • jellyrolljellyroll Frets: 3074
    A wardrobe? That's what I use.
  • BarneyBarney Frets: 628
    edited December 2016
    Iv got 23...lol....its a good idea though :)
    So you want to display 23 guitars?
    i use the 7 guitar racks from gear4music.
    They were about 35 each
    Well no ...more storage really and easy access...but iff it means taking them out of the cases and storing them on stands that would be as well....i just find a lot arnt getting played because they are awkward to access...
    Them guitar stands seem handy though with 7 racks ..thanks :)
  • Jack_Jack_ Frets: 3175
    Be careful, the cheap stands, and even some of the expensive ones don't react well with certain finishes.
    I personally prefer the case type stands, the Fender tweed ones if you're flush, or the Stagg ones if you're on a budget.
    There's also http://stand-made.co.uk/ if you want something special.
  • FreebirdFreebird Frets: 5822
    Guitars should be stored upright in their cases, detuned half a step down.
  • VoxmanVoxman Frets: 4972
    Yup, that's how I store mine (although I only have 10) - but why half a step down?  All mine are in standard tuning and I play most of them regularly.
  • SassafrasSassafras Frets: 30358
    Guitars should be stored at whatever pitch they're normally played in.
  • ToneControlToneControl Frets: 12256
    http://cdns3.gear4music.com/media/16/167733/1200/preview.jpg
    wall hangers, unless you are happy having them sideways in  a few of those  racks where the pots and pickups of each guitar is 1cm from the back of the next one
    https://58eca9fdf76150b92bfa-3586c28d09a33a8c605ed79290ca82aa.ssl.cf3.rackcdn.com/warwick-rockbag-7-multiple-guitar-rack-stand-f-p-rs20882-331698.jpg
    I used a 7 rack and it  was  just too  risky, especially  with bulkier guitars like semis
    where did you get that from?
    I'm   certain that's wrong
    Also very  much an obstacle to playing: every time you play you'd spend a few minutes repeatedly retuning whilst the wood catches up with the changed tension
    Not even everyone agrees that a slight detensioning is required to  post  guitar
    Cases exist to protect  a guitar during transport or adverse conditions
    If  your room is always 22C and 45% humidity, there is no reason at all to keep it in  a case
    I'd say it  was more natural for a guitar to be  uncased and have air around it
    The re is also the massive issue of whether a cased guitar will get played as much
    There is one more issue in a case: the strings being  pushed against the frets, causing  fret damage
    I've only seen  protector strips in Anderson and Suhr cases
    the other problem with storing  guitars in  their cases  is that they take up twice as much space
  • NeilNeil Frets: 3847
    If you store the cases upright it will be far easier to select from.
    I recommend the stand made wooden racks
    practical and lovely furniture too
    if you must go store bought the best guitar racks for me are the k and n ones
    well designed and small footprint nitro friendly and designed so guitars don't clang into each other
    http://www.dv247.com/studio-equipment/konig-and-meyer-17515--212326?gclid=Cj0KEQiAnIPDBRC7t5zJs4uQu5UBEiQA7u5Ne22p0-FZTYI1GgvZv2BRkgyFoz0PhaCBv3v0dFz4BCsaAoWE8P8HAQ
    I used to keep mine in a wardrobe!
     WOW ~ 23 wardrobes   :o
    that's even more than my missus !      ;)
