Although they may be offering more mids than you require.
Magnetic FX Satellite in which case.
I prefer to boost bass and treble a bit - but if you want something middier, try a modded tubescreamer like the visual sound route 808 - it has a bass boost that'll help you get a heavier overdrive sound but the treble roll off will let you not hurt your ears if it's into a bright amp.
I tried a timmy at high gain into a fender deluxe and it made my ears bleed!
Also a Tim, Cornish G2....
i didn't find a timmy that heavy as a standalone od, but then i usually use it as a boost so i might not have given it a decent try (or also might be misremembering since i tend to set and forget
What sound or player you trying to emulate ?
Ps. To be honest I'm using my Mojo Hand Zephyr over both of them for a low gainer at present, but that's a totally different beast entirely! Interested in Hudson Broadcast, EWS Fuzzy drive and Fairfield Barbershop too.
Pps. Sorry to the OP
