In a bit of a tight spot financially at the moment so this has to go, here are the specs as supplied to me by Fender:
Model Name: FSR Vintage Hot Rod '52 Telecaster
Model Number: 017-0150-(750)
Series: Telebration Series
Body: Premium Ash Body
Neck: 1-Piece Maple, “U” Shape,
(Gloss Nitrocellulose Lacquer Front with Satin Nitrocellulose Lacquer Back)
Fingerboard: Maple, 9.5" Radius (241 mm)
No. of Frets: 21 Medium Jumbo Frets
Scale Length: 25.5” (648 mm)
Width @ Nut: 1.650” (42 mm)
Hardware: Nickel/Chrome
Machine Heads: Fender®/Gotoh® Vintage Style Tuning Machines
Bridge: New Vintage Style Tele® Bridge with Three Intonatable Brass Saddles
Pickguard: 1-Ply Black Bakelite, (5-Hole)
Pickups: 1 Vintage Hot Rod ‘52 Tele® Pickup (Bridge),
1 Seymour Duncan® ‘59 Humbucking Pickup (Neck)
Colors: (750) Butterscotch Blonde,
("Thin-Skin" Nitrocellulose Lacquer Finish)
60th Anniversary Vintage Style 4-Bolt Neck Plate,
“U” Shape Maple Neck with Satin Finish on Back of Neck.
It weighs approx. 8.8 lbs so not the lightest. Has a neck shim installed by me to get the highish action I prefer, but plays perfectly well without it, just a lower action and a tad more string tension.
Note Callaham saddles are no longer fitted, instead it has fender compensated saddles, will update photos soon.
I have also rewired it with 500k pots so the neck pup sees 500k and the bridge 250k, with a .022uf cap for the neck and a second cap just operating with the bridge pup so it sees .044uf. Sounds much better this way, not so dark however the original harness with 375k pots will be included.
Comes with case and unopened case candy.
For some reason I can no longer post pics so
here is a link to the imgur album
Looking for £1000 £950 buyer pulled out so for sale again
Would do a partial trade for a fender classic 60's type strat or tele, or possibly a gretsch electromatic ideally need to raise £600-650 ish in cash out of the deal. SOLD
